hi guys, i just installed my HO alternator and noticed that my dash lights are dim and when i accelerate they go bright. also i am checking my voltage and its sitting at 14.5 and it jumps up to 16 volts for a quick second then goes back to 14.5. i also changed my wires to 1/0 gauge but went straight to the battery and not the distribution block you guys think that could be the problem? fyi the stock alternator never did that so im guessing i might even have belt slip because the pulley is much smaller than the stock one and has very little contact area
What vehicle
what alt
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
its a 1998 ford expedition and the alt is a 300a and does 240a at idle so it should have the power to not have any lights dim, my dash is dim without anything being on just the lights
Who makes the alt?
did you ground your alternator directly to the battery.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
If your alternator is jumping 2 volts with no change is rpms sounds like a bad regulator.
i does it when i accelerate not at idle and its happen quickly
yes i been reading on how to do the big 3 and i went to the battery so the battery has 3 grounds to it. the stock one the other to alt and another to frame
do you have an upgraded positive run ot the battery?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
