Port to small?
carshateme
I dont think he meant your subs as cheapo sub Was just an example
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
If that is the case. I'll apologize..but it's not the first time someone accused Audiobahns to being cheap-o's. IMO they sound good as some other subs....and they were affordable in my budget range...at the time.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
They are cheapo subs. It is merely a factual observation, but while you got upset at truth you missed great information. You even admit they were affordable on a little budget, don't be so defensive.
Did you already start cutting?
No. I have the measurements written down, I'm taking it to home depot to get it cut on their panel saw...
But that kills the volume I was going for. that's why I had it set at 3...I'm going out and cutting all this wood..so I need to measurements...correctly...so you're saying I need a 4" wide port with a 4" corner slit.
The calculations I gave you are for the exact same port as in your drawings, 4 inches wide port is enough port area 3 is below recommendation, Va/Vb is suggested to better be in the 12-16 range, larger port area will give better output in fact you will find that it's still short according to some but at least reaches the recommendation.
Take your time to have your facts clear before cutting of course, one other type of port that you could research if you are open to alternatives is a center port on the back with no turns.
Well I just want something to sound good..but look good at the same time. To the alternative suggestion. How would I construct that...like what would my measurements be...I'm not good with the ratio stuff. The current box I have constructed with the new port adjust is below. If you want to get me the measurement for the port lining the bottom center piece, I'll do it, that's if it'd improve my sounding quality.
what hes saying is u want the opining of the port to be 4 inches... then u want the port wall to be 4 inches from the back of the box... if im wrong he can correct me then
Yup, that's what he meant. That's how I reconstructed it. What he said about 3" port being too small is correct and I didn't realize it.
Car. Small trunk, Towards the trunk opening, Port towards to back seats, I'd put the subs towards my back seats...but my amp is mounted on a wooden board screwed on my back frame.
  • Who's Online   0 Members, 0 Anonymous, 6689 Guests (See full list)
