DC Audio Trunk Build 50.8db
lets hope!!!! i need to stop by kimos pick up the meter before i head home be there around 5:15 ...5:30
and i see no duct tape on the ports YOUR FUCKED!
:D gorilla tape adds DBs its on there.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
x2
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Have to resceduale something wasn't right.
.3 during normal operation maybe..you need it at least on rear batterys...when bass hits I bet you drop into 11s maybe less
We measured the voltage at the amps during a burp. Still .3 off from the stinger meter.
pop the cover off the stinger meter and use the pot in the upper right to calibrate it to whatever your DMM reads
glad to see you made it to the forum.. i had a feeling you would chime in on this. there are some real knee slappers that happen in this sub forum.. so be prepared.
that's what I did to match the voltage up front I think ill get another meter to read the back
If you don't hit a 151, I'll take one of your 5K's off your hands...by the way what ohm is each 5K seeing?
got each one wired to .7
  • Who's Online   0 Members, 0 Anonymous, 5415 Guests (See full list)
