Absolute min cu for 2 15s
ExtremeOz
Im looking at putting 2 15s in my 2 door hatch back but was wondering what would be the absolute minimum cu per sub be that people would use?
Right now i have 1 15 in a box thats 4.5cu tuned to 32hz. I want to try keep the box the same size as if i make the box any bigger ill have to pull the backseats out and i really dont want to do that IF i can avoid it.
Also what if i was to go sealed to fit them in would it be worth it?
6ft. Dependending on the subs, You may not notice a difference if any, going from 1 15 ported to 2 sealed. Also depends on power, Say you give the ported sub 1000rms and share that for the 2 sealed, that leaves you with 500rms a piece so not worth it IMO.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
Hmm ok. Well right now im feeding it 1500w at 2ohm when i put both in id be dropping them down to 1hm so about 3100w. There both DD9515 dual 4s.
I would personally remove the seats, Give your subs the ability to play at full potential. Your subs like big boxes from what I've seen in various tests. It's better to give them enough room then choke them, Also if you want to run a smaller than recomended box it generaly will not sound good unless you throw a ton of power at them
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
Good boxes less cone area > more cone area poor box 9 times out of 10
im running two 15's in a 4.5 cube box, it is punchy and has decent low output, but unloads on anything lower than 30 hz and its tuned to 35, but that being said, the box was made for low xmax subs to fit in a car, now its in my jeep. If i were you, the smallest i would do for 2 15s is 6-7 cubes min.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
that and i cant imagine a dd 9515 liking a sealed box at all..i wouldnt personally ever put one in a sealed box..theyre just not designed for it..and like the others said i wouldnt go blew 6 cubes net on those subs..good friend of mine had 2 of the same subs in a 6 cube box and they loved BUT he was feeding them double the power you would be (around 6k rms) so for ur amount of power i would do around 7-8 cubes if u can fit it
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Thanks for the info guys, Ill keep my current setup atm then.
good idea. :drink40:
2005 VW GTI 1.8T
(4) Fi BTL N2 15s/ 4th order bandpass
(2) Crescendo BC5500s
Crescendo c1000.4
(4) Selenium 6w4p (Q logic Kicks)
Crescendo FT1 tweeters
3 runs of 4/0
Too much 1/0
DC power Engineering 320 XP ~235A at idle
3 XS D3100s
  • Who's Online   0 Members, 0 Anonymous, 1380 Guests (See full list)
