4th Order blow-thru for 6 - 15's OPINIONS NEEDED!
Purplehaze
I can plug everything into sketchup if you'd like. I'm sittin at the girls house pretty bored and this would give me something to do lol
Yes please! That would be sweet!
I was gonna change the baffle a little, just a little angle, no real changes. just add 2" to the back side inner sealed width, and subtract 2" from the opposite side. If you could incorporate that, I would appreciate it!
Hell I appreciate it even if you can't! :drinks:
Thanks man!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
Thanks man!
thats what i was gonna suggest to get rid of any cancellation
Okay, so I came up with some new numbers, same design. See what you guys think of this one?
External: W 47" L 68" H 18"
Internal: W 45.5" L 66.6" H 16.5"
Sealed Inside:
W 7.208"
L 66.5"
H 16.5"
4.08ft3 x2
1.35ft3 per sub after displacements
Ported Inside
W 29.583"
L 66.5"
H 16.5"
16.89ft3 after port, sub, and bracing
2.81ft3 per sub
Port
H 14"
W 18"
L 6" - 3" external
14.92in2 port area per foot
252in2 port area total
46hz tuning
:popcorn:
just so you know the way the blow throughs are set up the tunnel effect is going to drop your tuning no matter how you tune it. so unless you like low low bass then id bring it up a little to 48 or so
also id try to make the port closer to 17 per.
but i like ground pounding so thats my opinon
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Thanks man, that's exactly what he wants. 50's in the low 30's. :clapping:
Hair tricks and super flex!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
then you should give more port area. id definitely bring it up to 17 or so
Already started doing it that way bub. lol What ratio are you trying to achieve? 2:1 I'm assuming. I noticed on your the figures you gave the area wasn't correct. So what are you wanting the internal areas on both sealed and ported sections to be at?
TEAM DC
www.dcsoundlab.com
2003 Tiburon GT V6 6 Speed
Ported Clam
6 12" DC Audio XL M2's
2 American Bass 1100.1
1 American Bass 350.4
3 D3100, 1 D975, 3 D925
Second Skin Damp Pro and Spectrum.
About 75% done
153.6 Sealed on dash at 34hz
Sealed Inside:
W 7.208"
L 66.5"
H 16.5"
4.08ft3 x2
Ported Inside
W 29.583"
L 66.5"
H 16.5"
2.81ft3 per sub
Port
H 14"
W 18"
L 6" - 3" external
46hz tuning
:popcorn:
^this. deep 4th order blow thrus are going to play low as balls. 1/4 wave theory. :shrug::good:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
So where should the tuning be? with the numbers i've got right now i'm at...
8.13 sealed before displacement of bracing
17.52 ported after sub and port displacement
17.19 area per foot
48.06hz tuning
2.16:1 ratio
TEAM DC
www.dcsoundlab.com
Ported Clam
About 75% done
The whole point or me doing a blow thru is for the massive low end response it is going to yeild. I wouldn't mind having some playability on normal rap songs in the upper span, but full tilt my goal is for 150s in the lower 30 hz range and just kill all the way down into the mid-low 20hz range...
And yes was going for a 2:1 ratio within the space I have.. It may be a little smaller than it probably should be but a stepside bed only has so much room
Laying frame soon.. System has to wait
So does the numbers I put down look good to you? If so I'll finish up the Sketchup and post it at those specs.
TEAM DC
www.dcsoundlab.com
Ported Clam
About 75% done
  • Who's Online   0 Members, 0 Anonymous, 1099 Guests (See full list)
