4th Order blow-thru for 6 - 15's OPINIONS NEEDED!
Purplehaze
What's up guys, I just finished this 4th order blow-thru design for Brandon(99fullsizechevy), and was hoping some of the big dogs(Ray or Ram or someone who has done 4th Order's) could take a look and see what I may have messed up!
Here is what I got, sorry it's so sloppy
Thanks for any input!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
The final dimensions are: 14.53ft^3 of ported, 7.42 sealed, 300in^2 of port area, 20in^2 port area per foot, tuned @51hz
Outer - W 47" x L 60" x H 18"
Inner - W 45.5" x L 58.5 x H 16.5
Inside of sealed sections (x2)
W 7.09 x L 58.5 x H 16.5 (x2)
3.96ft^3 before displacements (x2)
3.71ft^3 after bracing (x2)
7.42ft^3 of sealed total
Inside of ported section
W 29.8 x L 58.5 x H 16.5
16.75ft^3 before displacement
15.05ft^3 after sub and bracing
14.53ft^3 after port, sub, and bracing
Port dimensions
W 25" x L 6" x H 12"
19.88in^2 Port Area per ft
Tuning @51.4 hz
3" of port length is external
So, does anyone see anything I may have missed?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
i like it, for what my opinion's worth.
Thanks man, I appreciate your time! :drinks:
Your a SOTM winner, of course your opinion is worth something!
A lot, actually!
Anyone else care to chime in?
This is my first 4th order & my first blow-thru design, so I just wanna be sure of what I'm about to do.
And thanks again for your time and help!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Um I haven't really built one yet, but I'm about to, you could download winisd pro alpha and plug in those specs and see how it looks. It would at least give you a decent idea of what the box would be like response wise.
But from what I know it looks like it should be good.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Thanks man, I will have to get that & try it out 4 sure!
What subs and how much power per sub? I would recommend planning out your airspaces based on this first.
Subs will be Kicker CVR 15 d4ohm, and for amps - either 2 or 3 - AQ1200.1's. I can't remember for sure, maybe he can chime in?
And I was trying to do exactly that based off those subs specs. So, what do you think?
Also, thanks for your help! :drinks:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
I would listen to him, his blow through drops nasty low. And he is pretty good at designing things.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Those are 500w subs, I would go with 1.5ft3 sealed per sub and 3ft3 per sub ported. 14-18in2 of port per ft3 and tune depending on what type of music he listens to. Mine I have tuned to 46hz and it gives me a 28-70hz bandwidth.
I say you build it, stuff it in the PT for testing!
With only minimal 4th order experience years ago. I cant really help, sorry bout that.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
  • Who's Online   0 Members, 0 Anonymous, 6629 Guests (See full list)
