this is way easier than you all are making it out to be.
Wire each sub's coils in series. (2ohms)
Series those 2 subs (4ohms) Positive from amp to positive of 1st sub, negative of amp to negative of other sub, then connect the 2 remaining terminals. (should be a + and - from separate subs).
Do that to the other 2 subs (back to 2 ohms)
Done.
Yea, that's the other way to wire them, other than what I showed on page two. This way the subs and all their coils are IN PHASE, and not opposite phasing withing the coil.
And yes, each amp will see 1 ohm this way.
Ok, I got it now...
This will work. :drink40:
If you end up trying my way later, post the differences in scores if you will. I gained .4 db by wiring each sub in parallel instead of in series.
both negitive wires together on the amps ?
Both negative input terminals on the amps.
Run "jumpers" from negative terminals on master amp to negative terminals on slave.
Yes Joe that's correct.
Joe i wasnt messing around with you when i sent that to ya :good:
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
ohh wow, now i see what i did wrong, my bad, Maticus, you were right, i had an extra wire on each pair
edit: im going to delete my pics, i dont want anyone getting confused.
It's all good, everyone makes mistakes, and honestly I wasn't sure if I was the one in the wrong until I pulled it apart.
I just want to see this build go from questions to reality!
much props to maticus good job bro. now is there only one way to wire my 2 d4 subs to a single amp ?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
There is more than one way to wire them, but I am assuming you want a 1ohm load? then there is only one way.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
