WadeTustian Posted January 7, 2012 Report Share Posted January 7, 2012 hey guys, im wondering if anyone has a design or is willing to design be a sub box that i can build, its for a single kicker l5 12 and on the kicker site/ brocer it says this for street bass, 2.5 cu.ft. + port; 2.5x13.25" port, 16.5" long Power Handling = 600W please and thank you, it would be greatly appreciated thanks fellow smd! Quote 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/ Link to comment Share on other sites More sharing options...
WadeTustian Posted January 7, 2012 Author Report Share Posted January 7, 2012 or would this box do the trick, im looking for something similar to that? http://imageshack.us/photo/my-images/23/235cubes33hz325sqin3id.png/ Quote 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/ Link to comment Share on other sites More sharing options...
alaskanzx5 Posted January 7, 2012 Report Share Posted January 7, 2012 you could do a box that is 18"h x 28"w x 18" d with the port being 16.5"h x 3"w x 30 l. that gives you 2.81 cu ft before sub displacement and the port would be 17.62 cu in per sq foot before sub discplacement. im not sure on sub discplacement but i would say right around .2 so you would have .11 of air space you could take up for bracing. i would recomend atleast bracing the baffle. Quote t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
WadeTustian Posted January 27, 2012 Author Report Share Posted January 27, 2012 you could do a box that is 18"h x 28"w x 18" d with the port being 16.5"h x 3"w x 30 l. that gives you 2.81 cu ft before sub displacement and the port would be 17.62 cu in per sq foot before sub discplacement. im not sure on sub discplacement but i would say right around .2 so you would have .11 of air space you could take up for bracing. i would recomend atleast bracing the baffle. ok where finally going ahead with this, i like your idea, im just not sure on how long i need the port pieces Quote 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/ Link to comment Share on other sites More sharing options...
Joe X Posted January 28, 2012 Report Share Posted January 28, 2012 Based on Kicker specification (checked to be as you list above) here is a design suggestion, the size of the port parts are included: Enclosure Specifications: Fb = 39,807 Hz Vb = 2,5 ft^3 Subwoofer Mounting = Front Mounted External Height = 14,75 in External Width = 27,37 in External Depth = 16 in Port Width = 2 1/2 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 27 3/8 x 14 3/4 Left & Right Sides = 14 1/2 x 13 1/4 Top & Bottom = 27 3/8 x 14 1/2 L Port Internal Assembly Parts: Front to Back = 12 x 13 1/4 Extension = 1/2 x 13 1/4 Quote Link to comment Share on other sites More sharing options...
carshateme Posted January 28, 2012 Report Share Posted January 28, 2012 Designed accordingly to what kicker recommends. Flush sub mount, can be added. Quote New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center] Link to comment Share on other sites More sharing options...
WadeTustian Posted January 28, 2012 Author Report Share Posted January 28, 2012 Designed accordingly to what kicker recommends. Flush sub mount, can be added. wow thanks for that. i went with that box that i posted up above, i did make it 16 inches tall rather then 14.5 and its coming along nicely, i used box calculator and it says that its tuned to 34hz and that site said it was tuned to 33. I'm just worried about bracing, is that the only place i should brace or should i brace another place also Quote 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/ Link to comment Share on other sites More sharing options...
carshateme Posted January 28, 2012 Report Share Posted January 28, 2012 (edited) Well if you want to over kill on bracing, you can add one on both sides of the subwoofer, but it may not be necessarily. Edited January 28, 2012 by carshateme Quote New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center] Link to comment Share on other sites More sharing options...
WadeTustian Posted January 28, 2012 Author Report Share Posted January 28, 2012 so i should be good with only 1 brace in the port? ive never built a box befor so sorry for the noob questions Quote 2007 Mazda 3 Sedan Pioneer 80-prsB2 Zero.7 2 15s 4inch coil psi recones temp til my subs are reconedFocal P165-v15Audison voce quattro fully activeOnly gonna get louder 146.1 at 38hz 138.x at 24hzBuild log http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/ Link to comment Share on other sites More sharing options...
412 CVX Posted January 28, 2012 Report Share Posted January 28, 2012 you really shouldn't need the brace in the port unless the sub is firing up. it's an L5, i'm assuming not seeing that much power. my buddy overpowered his 10" L5's in the standard kicker box, and had no problems.. if anything i'd do a double baffle Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
