box design?
hey guys, im wondering if anyone has a design or is willing to design be a sub box that i can build, its for a single kicker l5 12 and on the kicker site/ brocer it says this for street bass,
2.5 cu.ft. + port; 2.5x13.25" port, 16.5" long
Power Handling = 600W
please and thank you, it would be greatly appreciated thanks fellow smd!
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
or would this box do the trick, im looking for something similar to that? http://imageshack.us/photo/my-images/23/235cubes33hz325sqin3id.png/
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
you could do a box that is 18"h x 28"w x 18" d with the port being 16.5"h x 3"w x 30 l. that gives you 2.81 cu ft before sub displacement and the port would be 17.62 cu in per sq foot before sub discplacement. im not sure on sub discplacement but i would say right around .2 so you would have .11 of air space you could take up for bracing. i would recomend atleast bracing the baffle.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • 3 weeks later...
ok where finally going ahead with this, i like your idea, im just not sure on how long i need the port pieces
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
Based on Kicker specification (checked to be as you list above) here is a design suggestion, the size of the port parts are included:
Enclosure Specifications:
Fb = 39,807 Hz
Vb = 2,5 ft^3
Subwoofer Mounting = Front Mounted
External Height = 14,75 in
External Width = 27,37 in
External Depth = 16 in
Port Width = 2 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 27 3/8 x 14 3/4
Left & Right Sides = 14 1/2 x 13 1/4
Top & Bottom = 27 3/8 x 14 1/2
L Port Internal Assembly Parts:
Front to Back = 12 x 13 1/4
Extension = 1/2 x 13 1/4
Designed accordingly to what kicker recommends. Flush sub mount, can be added.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
wow thanks for that. i went with that box that i posted up above, i did make it 16 inches tall rather then 14.5 and its coming along nicely, i used box calculator and it says that its tuned to 34hz and that site said it was tuned to 33. I'm just worried about bracing, is that the only place i should brace or should i brace another place also
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
Well if you want to over kill on bracing, you can add one on both sides of the subwoofer, but it may not be necessarily.
Edited by carshateme
so i should be good with only 1 brace in the port? ive never built a box befor so sorry for the noob questions
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
you really shouldn't need the brace in the port unless the sub is firing up.
it's an L5, i'm assuming not seeing that much power. my buddy overpowered his 10" L5's in the standard kicker box, and had no problems.. if anything i'd do a double baffle
More box builds
I'm with captain stupid.
  • Who's Online   1 Member, 0 Anonymous, 1030 Guests (See full list)
