6 DC XL 12's clammed in a Tiburon (she's alive!! vid on pg 12)
WoW! If someone didnt already know its a coupe, one look into that wall tunnel it seems like an SUV. Cant wait to see the end product.
That foam actually was used just for the purpose of sealing it off. Just used painters tape on headliner and started spraying. She hasn't been tortured... yet
Seems like i gotta use foam in the method you mentioned. I normally only use foam in hollow area to fill them up. :)
Beg to disagree on torture part. At 150db if you are not torturing then we both have the wrong sense of the term torture. lol! I guess with 2 level 4 XL you did close to 155db, right.
Here is my build! I dropped a link to yours in it since your pushed me to do it. I was lazy. :)
http://www.stevemeadedesigns.com/board/topic/150530-neoglow-designs-project-dc-stage-1/
Thanks for the comments fellas.. got some more work yesterday but didn't get any pics due to most of work being done at night. Rear end is completely torn apart.. No batts, wire, amps, nothing. I'm at it again today with goal of having rear end put back together, batts installed, amp rack made, and amps wired up. And if I have the time baffles will be installed as well.
And neo I hit a 153.0 with the 18's and I know it was a bit of torture but nothing compared to what she's about to go thru.
TEAM DC
www.dcsoundlab.com
2003 Tiburon GT V6 6 Speed
Ported Clam
6 12" DC Audio XL M2's
2 American Bass 1100.1
1 American Bass 350.4
3 D3100, 1 D975, 3 D925
Second Skin Damp Pro and Spectrum.
About 75% done
153.6 Sealed on dash at 34hz
Would it help to put in an angled wall to those flat faces that will be behind the sub wall, the vertical narrow walls and that going along the floor of the wall?
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
this is absolutely insane! my best friend used to have a tiburon, so i know just how tiny those things are. but great work nonetheless! cant wait to see the finished product
I'm going to be doing steel from baffles to side walls and have steel cut for to run along top and bottoms of both sides of them.
Yea dude they're tiny. With a little imagination and push you can do a lot in a tiny space tho. Once example of what I mean is with the pics I'm about to put up. I now have room for 2 more d3100's from me finding another place for the 2 that I just got the other day.
TEAM DC
www.dcsoundlab.com
Ported Clam
About 75% done
Little bit of an update.. more later on tonight
Where I left off last night.
Little bit of wire torn out.
Hmmm... this could work :)
D3100's wired up
D925's in
That's all I have as of now. more to come. Need to do some thinking on how I wanna go about next step which is the amp rack
TEAM DC
www.dcsoundlab.com
Ported Clam
About 75% done
Good stuff bro, just read all 10 pages, can't wait to see the rest
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
Still needing to get some spacers put on the rear but like how she sits now. almost stanced... but not quite
It'll be stances after your finished;)
& just read all 10 pages looks good
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
I've got adjustable coil overs so I can slam her whenever Zach :) Need spacers more than anything.
Got a little bit of an update. and one of my visions coming to life! Nuff chit chat on with the pics..
Little bit of wire.. still need more for the triple inputs tho
Amp rack coming together.
Sry it's not as much as I hoped but ran into couple issues along the way...
Like always enjoy and stay tuned :)
TEAM DC
www.dcsoundlab.com
Ported Clam
About 75% done
