BoxHeight=20
BoxWidth=38
BoxDepth=38
PortHeight=8
PortWidth=18
PortLength=24
SubDisplacements = .8
BaffleThickness = .75
CommonWalls = 0
in torres box calc. ill get photobucket thing up when my comp quits bein slow :shrug:
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Not sure what box volume these subs like, 2.75 cubes/sub seems a bit small for 15s. Might want to try a double baffle too. How much power do you plan on running?
Edit: Ninja'd by Mr. Fosgates himself
Edited by SnowDrifter
it says 600 rms so probably 3 or 4k. just need to find decent amps on the remotely cheap. this is more a budget build than a balls out build. is dbdrive a good brand for amps?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Double thickness on the baffle face and some bracing are in order to say the least. Also if the port is in the same face as the subs, seems a tight fit. Probably some sketchup work on it will help you put things in proper light.
subs up port front. i have no tailgate
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
So check the sub upward option so that the port gets properly calculated and I would add a cross brace at least in the center of the baffle face.
Edited by Joe X
ok
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
  • Who's Online   0 Members, 0 Anonymous, 2846 Guests (See full list)
