Any one know where I can get some wheel adapters.I need to make this convertion 5x127 patter to 5x110 the rims are on a 2004 malibu ls and want to fit them on a 1985 S-10 Blazer.Any suggetions will be appreciated.
You'll need new axles and front hubs with the new bolt pattern cause there are no adapters for converting them, either the rims have special bolt patterns for multiple sizes or they're a one size only fitment.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
why on earth would you want the stock malibu rims anyways.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
id try a local shop if u can find one
ebay
google it up- here is a site i found http://www.ezaccessory.com/Billet_Wheel_Adapters_s/25.htm
they should sit with in the fenders and not mexi flush since its going from a malibu to a blazer
when YOU DO find the adapters, make sure the hubs are clean of corrosion or rust, then put loc tight on the studs, then torque them to specs
i run dome spacer/adapters on the rear of my jimmy and even with the 24s ive never had a problem, found mine locally GL
there not stock malibu rims there 20'' rims.But now I'm doing a build on a blazer and want to see if I can fit the rims.
ebay
thanks I'll check it out.
