L shaped port tuning
my box dimentions are 33width x 15high x 25long and my port is 4.5wide x 13.5high and i want it tuned to 32hz. what should the port length be?
Edited by lotus
2010 Cobalt LT Coupe
Subs: 2 American bass XFL 12s
Amp: Crescendo BC3500D
Big 3 in 1/0awg
29hz box
stinger volt meter
2nd battery Deka 9a31
pioneer DEH-9400BH
Port length of 25inches puts you at 32.39 before displacement of subs or bracing. That's total port length too, so if it bends, which it does, you add the length together
do u calculate the subs displacement also for tuning?
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
Yup, all displacement needs to be taken into account.
so if i want 32hz how will i get it exact? i have 2 12" XDs and useing 3/4" MDF
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
You should take a look at the Torres box calc. It will help you answer a lot of your questions.
A 12" roughly displaces .14 cubes of air. Two of them is .28 cubic inches. 27 or 28 inches of port length corrects for the displacement of the subs. It also gives you 14 sq inches of port per cubic foot, which is solid.
okay so i get about 5.4cu, so for a tuning of 32hz i should just go 27 then
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
Based on a 0.14 cubic feet driver displacement and 2 drivers you can build on these dimensions:
Enclosure Specifications:
Fb = 32,0 Hz
Vb = 4,257 ft^3
External Height = 15 in
External Width = 33 in
External Depth = 25 in
Port Width = 4 3/4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 33 x 15
Left & Right Sides = 23 1/2 x 13 1/2
Top & Bottom = 33 x 23 1/2
L Port Internal Assembly Parts:
Front to Back = 18 3/4 x 13 1/2
Extension = 5 1/2 x 13 1/2
I used a slightly wider port get passed the corner of the box since it was rather near to the back wall.
  • Who's Online   0 Members, 0 Anonymous, 1428 Guests (See full list)
