Scratchy sound coming from sub
the only other thing that could of happend is a piece of metal (a very small piece like a shaving) or a small piece of wood made its self into the sub from the sub vents and is stuck between the coil and magnet it is possible but unlikly
What about a screw?
lmao that is still the crazest thing ive seen inside a sub when i opened it up not just a screw a fucking gianormus fucking lag screw under the dust cap
Yeah, that sounds like a bad connection, could be anywhere from your source to the amp rca's. Check connections for tightness and cleanliness. sounds like when you use an iPod and the headphone jack is dirty and you wiggle the jack around to clean it.
what kind of amp you running, shitty amps will do those things, if anything i would replace your rcas and see what that does, but just check and make sure every connection is tight and clean..id deff start with your rcas if not then get a new amp..i never hered of anything like this happen before haha
Its an infinity amp.. and Im pretty sure its the amp. I hooked it up to the front channel & it worked fine..
gonna replace the RCA cables as it seems its that.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
So I think it MAY be a problem with the right rear channel. I hooked it up to the left rear and it seems to be bangin right.
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 1680 Guests (See full list)
