electrical advice please.
right now i have 2 15 re audio sxx's hooked up to a kicker kx1200.1 and i already have serious voltage drops. when i upgrade my amp i know i need a ho alt. my only problem is i have no idea what size i should get? also i have 2 yellow top batteries just laying around can i use these for my battery bank rather than buying something else? any and all help would be greatly appreciated.
2005 ford explorer xlt limited 4x4
2 xs power d3400s
2 runs of shca
mid/ highs- infinity 6x8 3 ways
2 18 ssa icons
2 aq 1200.1 @ 2 ohms
10 cubes tuned to 36 hrz
You need a good agm battery under the hood, and then yes, you can use the yellow tops...although they would not be ideal.
Do the big 3 in 1/0, as well.
With all of that, I can't imagine there would be much voltage drop, if any at all...with the 1200.1
Depending on how much power you are upgrading to, you may need a high output alternator. Check out singer alternators.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
well i'm actually looking in to just giving this system to the ole lady and setting up for 2 ssa xcon 18's so i'm looking at around 4k. any suggestion on how to run 1/0 in an explorer?
2 xs power d3400s
2 runs of shca
2 18 ssa icons
4kw is going to be pullin around 350 amps itself.. Depending on what alt you get will determine your battery bank.. Generally a large yellow top is good for like 1kw each I think when added as secondary battery's..
So keep in mind you going to need to support around a 400-430 amp current draw..
Btw there is a section for electrical so general audio is not the place for this thread..
Laying frame soon.. System has to wait
350 amps?
  • Who's Online   0 Members, 0 Anonymous, 1615 Guests (See full list)
