I was thinking abou this the other day and was wondering if you have let's say a 4 ohm SVC sub like a 9500 or something, could you take a 4 ohm resistor, wire it in parallel, and make the ohm load 2? Or is it not possible since resistors aren't polarized?
You mean to get louder making a 2 ohm load? It won't get louder because the extra power you would be getting from the amp would turn into heat in the resistor not into sound. Besides who knows what resistor would handle that much power.
I believe it's capacitors as bass blockers. Your sub is basically a resistor
A resistor(resistance) is for DC , a voice coil gets AC so it is an inductor(inductance).
Edited by 87regal
A lot of bad info here.
Caps are polarized, not resistors.
As long as you use a non-inductive resistor, it will not affect the signal or frequency response.
If you created a coil from wire, you have created an inductor, which will change the frequency response.
The correct answer to the OP question should be:
Even if you parallel enough resistors to do this, it is a waste. Let's say you have an amp that does 500 watts at 4 ohms and 1000 watts at two ohms. The 4 ohm sub gets 500 watts. Add the resistor in parallel (and assume it is VERY high power), and your amp now outputs 1000 watts. But guess what - 500 watts goes to the sub and 500 watts goes to the resistor. Nothing gained but some additional heat and stress on your electrical.
thank you! lol. i was doing a face palm to every response in here.
