rockford 1500 bd cp
BassMunky
ill be getting it for 350 not bad ideal ehh? what size battery should i get in the back than?
what size fuses should i get for after and before the 2nd battery? i already have a fuse after the front battery i think it a 250
Edited by BassMunky
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
I ran Rockford amps for two years and I gotta say they work great in any set up. If you are really concerned just keep the gains down. But I don't think you will have any problems
i wont be able to set it with a smd detector till end of next month soo where should the gain be set? about 5/16 to 3/8 on the gain
ok, 1st the rf 1500.1bdcp usaully do 1800-1900 at 1 ohm 1700-1800 at 2ohm, i wouldnt push those subs passed 1000watts a peice so even at 1 ohm doing 1900 watts you will only be at 950 per so your good. second, you will need a second battery maybe more. these amps are beast i have one. it will get those subs moving great and if you can get the amp for 350 thats a great deal dealers pay about 500 a piece on them. you should consider saving up for a ho alt. make sure you build a box for those subs to, take some time designing it and brace the box fairly well.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
thankyou for answering first question
2 other questions?
how do i use the wired bass knob and set it ?
how many fuses will i need for my setup?
Edited by BassMunky
where u gettin it for 350??
  • Who's Online   1 Member, 0 Anonymous, 1073 Guests (See full list)
