ChevyBoy95 Posted January 17, 2012 Report Posted January 17, 2012 I have searched, taken off the air cleaner, and looked all over and cant find where it goes. 1995 Chevrolet truck goes down under and i cant see where after. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Ray Posted January 17, 2012 Report Posted January 17, 2012 I think it was for a block heater 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
kickass audio Posted January 18, 2012 Report Posted January 18, 2012 Im not sure what you mean by checking the air filter but sometimes there is a plug like that on the ribbed part of your intake lines for the engine. Its a small o2 sensor that will detect how much airflow is being taken into the engine so that it can get a good air/fuel mix. If that is whats loose your engine will start but stall out after a few seconds of running the engine. If the engine will run just fine without any shudder then your intake is hooked up right. The only other thing i can think of for something that small on that engine it could be the block warmer like Ray said or maybe a sensor on the a/c to regulate the pressure and monitor it. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
fox_racin4 Posted January 18, 2012 Report Posted January 18, 2012 are you trying to figure out what it is, or where it plugs into? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Ray Posted January 18, 2012 Report Posted January 18, 2012 Ambient air temp is built into the maf on that truck I say if it runs and no cel then fukk ettt 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
ChevyBoy95 Posted January 18, 2012 Author Report Posted January 18, 2012 nvm guys, i found it. the truck i have has a light under the hood that can be pulled around under the hood (has a 6ft wire on it) and a casing where it winds into. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
