virtually every ipod clips when they're turned all the way up if you use the headphone jack. turn the volume down to like 90% and retest
use USB connection not the headphone jack iPod's internal amp sucks donkey balls
dont have one bro.. im going to put the test tone on my laptop and try that if all fails ill buy a head unit and try that i guess.. my buddy should be over today ill hook it up to his amp and see what happens
if you feel your unit is damaged, you can send it in and we will take a look at it.
email me your info at [email protected]
thanks! :)
Follow my Tweet (Twitter)
Here is a couple of things to check:
1. Did you turn off sound check on itunes? (sound check will change the level of the tracks to a normalized level and the tracks will no longer be calibrated)
2. When you ripped the tracks off the disk did you use the highest bit rate available? (Low bit rates will cause distortion in some cases)
Please check every component down the signal path or test the DD-1 on another set-up to verify if defective.
You can send the DD-1 in for us to check and service if a problem exists.
Juan Rodriguez
Chief Technology Officer
D'Amore Engineering
T15KW Support Engineer
System.
KVT512 Kenwood Fold Out Monitor
Epic-160 Audio control Indash epicenter
(1)T1500-1BD with T2000.1 Transformer 1700 watts at 2 ohms
(2) T600-2 with T800-2 Transformers 320/ch at 4 ohms
(2) QSD216 Q series MB Quart 6.5 inch components
(3) P3D212 Rockford P3 12inch Subs
(1) Very Loud Altima Coupe!
thanks for the comments every one i really appreciate yalls time just hooked it up to a buddys system and it does what its supposed to do it doesnt show clipping then you turns it up and the clipping light comes on when turned to high as the dd-1 should so im guessing my clarion eqs746 has an internal issue but yes i made sure to rip the files using the loss-less like it says in the manual
Glad to hear your distortion detector is working well. Our defective rate is really really low on the tool. Glad that you've tried it out on another setup. If the distortion light is on, there is distortion somewhere. We have found the following with the DD-1 by having issues like you had:
* Bad line output convertors
* Bad ground loop isolators
* Bad iPods
* Bad headunits
* damaged amplifiers
* distorted signal processors
Its pretty amazing what it can stiff out, good luck!
* Bad iPods
* Bad headunits
That's a long list of side affects.... Is this product made by Pfizer??
Amazing how long it took before someone made a simple tool this useful.
