VGA to HDMI Converter
as the title says can someone recommend a good quality vga to hdmi converter
i understand that you are not able to go from vga to hdmi with a simple cable
any help would be great
Vehicle: 2017 Chevrolet Silverado High Country
Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48
Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3”
Subwoofer: (4) B2 Audio XM 8’s
Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6
Processors: NavTv M650 (integration), Helix DSP Pro MK2
Silverado Build Log
They make them, but IIRC it has to be DVI to HDMI. It isn't the only way you can go though. You can also get a VGA to RGB cable. Since VGA is an RGB output (I believe so anyway) you would be better off going that way if you don't have a DVI output on your video card. Assuming your TV has RGB (component) inputs, which it probably does.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
well ive heard you cant just use a cable because one is analog and one is digital and the only way for it to work correctly is to use a converter box
Silverado Build Log
cant some converter boxes convert the vga signal to hd..maybe not 1080 but something close?
just trying to hook my laptop up to my tv and my tv doesnt have vga and my laptop doesnt have hdmi
Silverado Build Log
i guess, i am not 100% sure it could be like those dvd player that have HD up-conversion... not really HD though.
if you just want to connect it use something like this
http://www.eforcity.com/80811.html?efprcggbadtf120118=sc+gb+80811&utm_source=google&utm_medium=product_search&utm_campaign=google_base
you win some, you lose some
I believe that is true for directly from VGA to HDMI.
I run a DVI to HDMI adapter for using my LCD tv as a monitor. One like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812270286
For VGA to RGB I've used a cable like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16882719408
If it's for a laptop, the VGA to RGB would probably be the best choice, in my opinion. Then you'll also need a 3.5mm to RCA connector for sound.
My Saab 9000 build
