Here is a design suggestion:
Enclosure Specifications:
Fb = 30 Hz
Vb = 8 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 20 in
External Width = 27,54 in
External Depth = 38 in
Port Width = 5 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 27 9/16 x 20
Left & Right Sides = 35 3/4 x 18 1/2
Top & Bottom = 27 9/16 x 35 3/4
L Port Internal Assembly Parts:
Front to Back = 25 1/2 x 18 1/2
A fair amount of bracing should be added though.
probably not going to work since his trunk slopes down to 17"
Right, not using his full depth though.
So taking away some more depth hopefully it will fit:
Fb = 30 Hz
Vb = 7 ft^3
External Width = 32,67 in
External Depth = 30 in
Port Width = 5 1/4 in
Cut List:
2 x Front & Back (3 parts) = 32 11/16 x 20
Left & Right Sides = 27 3/4 x 18 1/2
Top & Bottom = 32 11/16 x 27 3/4
Front to Back = 22 1/2 x 18 1/2
Extension = 3/4 x 18 1/2
Edited by Joe X
thanks alot i really appreciate the help. my trunk is weird shaped and that leaves less options for designs. i'm going to do a test fit with some scrap wood and see if it will fit.
I can change keep changing dims, Hope you can fit a big enough right angled box as those are the easiest to build.
  • Who's Online   0 Members, 0 Anonymous, 1119 Guests (See full list)
