toad559 Posted January 31, 2012 Report Posted January 31, 2012 you should see around 3db gain from x2 cone and power. for my wall, of 4 15s, on 1 9k@1ohm i burped a 154.3, then after the 2nd amp strap @1ohm, i did a 157.4, both seal. 3.1db gain. and i blew a surround after that lol. so basically only like 5 mins of testing. with the right adjustments, you be gooD!!! got the right stuff. Fresno, Cali 559
dwright27 Posted January 31, 2012 Report Posted January 31, 2012 53.2 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
heckvr4 Posted January 31, 2012 Author Report Posted January 31, 2012 154.8 @42hz sealed music tl numbers video still uploading im hoping to gain a lil more than 3dbs with 16v batts/system clamping the 9k soon... edit , just noticed my voltage stays above 17v the whole time 05 f150 4 18'' DC lvl6 2 DC AUDIO 9.0ks 161.3 @ 44HZ build log here96 tahoe http://www.stevemeadedesigns.com/board/topic/160522-8-18xls2-dc-100k4th-order/page-9
AA98hoe Posted January 31, 2012 Report Posted January 31, 2012 Its possible toad did it..... nice score for 2 subs in a 4 sub box:-).... def tuned in TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
heckvr4 Posted January 31, 2012 Author Report Posted January 31, 2012 you should see around 3db gain from x2 cone and power. for my wall, of 4 15s, on 1 9k@1ohm i burped a 154.3, then after the 2nd amp strap @1ohm, i did a 157.4, both seal. 3.1db gain. and i blew a surround after that lol. so basically only like 5 mins of testing. with the right adjustments, you be gooD!!! got the right stuff. ill be happy with a 3db gain. numbers are not my goal with this setup... 05 f150 4 18'' DC lvl6 2 DC AUDIO 9.0ks 161.3 @ 44HZ build log here96 tahoe http://www.stevemeadedesigns.com/board/topic/160522-8-18xls2-dc-100k4th-order/page-9
FieroGrande Posted January 31, 2012 Report Posted January 31, 2012 Damn that's a wild score with what is in there now. Good job so far. I can't wait to see the tests with the different amounts of wire going into the amp.
heckvr4 Posted January 31, 2012 Author Report Posted January 31, 2012 I migth test the inputs later today . After i clamp one of my 9ks. 05 f150 4 18'' DC lvl6 2 DC AUDIO 9.0ks 161.3 @ 44HZ build log here96 tahoe http://www.stevemeadedesigns.com/board/topic/160522-8-18xls2-dc-100k4th-order/page-9
C-Fizzy Posted January 31, 2012 Report Posted January 31, 2012 nice scores so far. not only should you gain with 2x cone/power, but you should gain as well due to the subs seeing the proper airspace with all 4 being in the box together. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
mazdaspl Posted January 31, 2012 Report Posted January 31, 2012 Nice score man.. Don't know if anyone else seen it, but I noticed almost no voltage drop on your voltmeter.. starting at 17.9 to 18.. dam!!! Jay
ssackett Posted January 31, 2012 Report Posted January 31, 2012 Curious on dbdrag style an meca..... nice numbers bro...what's the 9k wired too if I missed it USACI is the only big organization that comes to Colorado , so im used to testing 'outlaw' i dont even know the rules on mic placement for other org's besides outlaw and sealed on winshield 9k is wired @ .7 thanks, like i said before , i was really surprised on the numbers i got. i have about 13 cubes per sub rite now Great number! Someone must have built those subs nice, 13 cubes per sub is huge LMAO. Team S.S.C. DB Drag Street A 2011 National Champ DC Audio Dealer Nor Cal AA Dealer Incriminator Audio Dealer CA Sundown Audio Dealer [email protected]
