low voltage problem
With the car on check the charging voltage coming off the alternator. If its low like you were saying than the alternators bad. When was the last time you topped off your battery?
you win some, you lose some
It's 13.7v
Battery was fully charged little more then a week ago.
Hmm 13.7 is a little low but not too low.
low for car audio.
What's the batteries resting voltage?
It's sounding more and more like it's the alternator than anything.
batteries resting voltage is around 12.4-12.6
The biggest problem I saw so far is when I turned my music up to fult tilt and voltage dropped to low 12's, but once I turned it off, it stayed at 13v for a little bit and then slowly started to move back up to 13.7/13.8. Befero, it would jump back to 14v.
disconnectyour batteries from each other and test them individually. 12.4 -12.6 is low low low. get it up over 12.8 at the lowst.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Your d3100 should have a higher resting voltage than that, it seems like your alt has had enough abuse and needs to be replaced. It'll probably continue to go slowly or just stop charging all together. With my experience with XS batts is they usually rest above 12.8
Damn you n8 nijaing me like that <_<
arent you running at .5 too? Im surprised it lasted this long.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I just have 1 battery.
Gonna disconnect battery and re-check voltage.
scratch that disconnecting thign. I thought you had one in front one in back.
Its your alt then. 400 ampsof current draw on a 120 amp alt will do that.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 823 Guests (See full list)
