just build a new box the port recommended specs. sealed net volume and port net volume are different. cant just add ports to a sealed box.. if you want to do it properly at least
you should just by a prefab sealed box and cut some holes in it...lol
on a serious note you can make a nice port out of the spacers cut the center out then cut the back of the spacers to make a port
:lol:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
he said the specs were for ported he then put spacers in it to make it sealed
you could just unscrew the screws and knock out the spacers, or you could cut them out from the inside with a jigsaw. Or just leave it and use 4" pvc for both sides, just giving you some ideas.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
oh..
to op, why didnt you make it ported in the first place lol did you glue and caulked the inside? if so then it will be a bitch trying to alter the box and could possibly mess something up. i just say build a new box
I would say new box trying to move anything that has been glued and screwed is extremely hard, if you can get some good swings with a hammer, If you can't swing a hammer vey far inside the box forget it.
The Midget Looks Into Your Soul
2008 Dodge am 3500HD with the 6.7 Cummins
Race Me tuner, dpf deleted
kenwood double din
cheap walmart speakers for now(infinity reference comps comps coming soon)
2 kicker L5's in a ported box of unknown tuning lol(soon to be changed)
Power acoustic 1500.1 on the subs (for now)
Ok hopefully this gets viewed again.sorry for the misunderstanding,Here we go..I have 2 12's in a box that was originaly suppose to be ported.I decided i was going to slap some walls inside the box and call it a t-line.When i got to that point i realized my measurement was off so i said screw it and I went with the original design(almost)..Yes i have two walls inside the box that spaces the 2 12's.The walls only run 12-1/2 inches to the back of the box(top/bottom is 32inches long and 20 inches deep.that gives a gap of 7-1/2 inches from the end of the spacers to the back of the box(kind of like a ported enclosure) all i have to do now is cut the box in between the spacers and ill have a ported box.I dont have to cut the spacers there is already a 7-1/2 inch gap in the back for air to flow between the 12's.My question is,could i port this box with out destroying what little bit of spl i have.the original design called for a 3x15 inch port(the space between the spacers) but i messed up so now the gap between spacers is 4 inches.at 3 inches it was tuned for 40htz what would be the tuning at 4 inches and should i port it or leave is closed? I am really trying to pull any spl I can
R.I.P...99'Dodge Grand Caravan
03 Lancer Oz
Big 3
HU-JVC KD-530
RCA's-rockerfosgate
41/2 inch Infinity mids
Subs-(12's)2 Orion xtr124
Amp-Coustic600se
battery-2 x stock, 1x Shuriken SK-BT20
Box-L-ported 3.562cubes@35Hz
miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive)
I dont have flex yet but damn I sound good,(coming soon....flex)
Check out my HHR install
Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/
Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
port that bish! it will be wayy louder
and for tunning i can't understand you messurments
give me how high how wide and how deep
i got a 4 inch port and how log is each divieder i will tell you your tunning
ok it is 16 inch high, 32 inch wide, and 20 inch deep(chamber depth) it has 2 spacers that is 15 inch tall, and 12-1/2 deep.both port walls or spacers are 4 inches apart.
Edited by MrFree
03 Lancer Oz
Big 3
HU-JVC KD-530
RCA's-rockerfosgate
Amp-Coustic600se
top 20"x33", bottom 20"x33", front 15"x31", back 15"x31", sides(x2)15"x20" plus in the inside there is 2 panels that are 15"x121/2" they are spaced 4 inches apart(sorry for sounding like a broken record,this half ass build has consumed me.I just want to bump)
03 Lancer Oz
Big 3
HU-JVC KD-530
RCA's-rockerfosgate
Amp-Coustic600se
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
