I am about to order my HID's and have a stupid question.
Will having DRL's (daytime running lights) mess with my HIDs?
yes disable them
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
pontiac g6 still has drl fuse in and no problems. I like it because it turns off my head lights if i forget
edit: turns ON!
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
well i have a 97 s10, I am about to put the 97 blazer front end on it, so i am going from 1 bulb hi/low to 2 separate bulbs.
N8 there is a relay for that right?
i know for 88-98 is simple pull #15 fuse. not sure about later years
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Guess i might have to go out and look
Posted (edited)
My g6 had a fuse that I pulled. Check your fuses and see, but if not I'm sure there is a way to bypass it if you wanted.
edit: turns ON!
Don't all g6's have auto headlights? That's not the same as DRL so if you pulled that fuse your headlights will still come on when it senses it's dark.
Edited by nautical7
Yea i pulled the fuse tonight when i went out to pick up some headlight socket pigtails.
my 00 gmc jimmy it has the same thing, i disabled them
theres two ways(that worked for me)....push the ebrake just enough to set the dash light off(then take the bulb out) or on the right dash speaker cover, there is the sensor that turns them on, unplug that
  • Who's Online   0 Members, 1 Anonymous (See full list)
