Can someone lower the tuning in this design?
~CURRENT PLAN~
Outer dim.
16" high
28" wide
30" deep
Port
2.5" high
26.5" wide
26" long
Net vol. 4.13 ft.^3
tuning freq. 36.33hz
Port area per ft. 16.03 in sq
~The port is across the bottom on this box design~
i have most of my box built, but i decided i wanted more of a lower tuning like my current box at 30 hz. I love the lows. Can someone change the port length for it to be a little lower, aroundish where my current box is tuned to? If possible I would appreciate it very much.
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
by going that low the port is going to need to be stupid long like 50 inches. so long that the internal volume left over after port displacement will be closer to 3 cubes. i think you will need to think about smaller port area to reach 30hz
if you are using the dd sub in your avatar i wouldnt go lower than 36. in car tuning will be lower anyways.
what dd says about it
http://ddaudio.com/faq/what-to-tune-box-port-to.aspx
Edited by rogue
need to know what sub(s) your running. I put your dimensions in Torresand your tuned to 34 hz now. If you extend your port to 27 inches you'll drop down to 33.77. But like Rogue said if you keep extending your port to tune lower your going to take away from your net volume. Then your port to net Cu. ft. ratio will be off.
Who cares!!!
OP - The issue is that as your port becomes longer to lower the tuning, the net volume becomes lower, making the tuning higher than you calculated. Your port has to be even longer than you calculated, which will further lower the net volume and again not give you the tuning you calculated. It is an iterative process (along with a little predicting) to get you where you want to be.
In your design, you can only go .75" deeper, then you will have to turn up.
I am also confused on your current design - I come up with well over 4.13 cuft net volume. What is your sub and bracing displacement? How thick is the baffle?
Using 14.5 x 26.5 x 28.5 = 6.34 cuft
Port - 26.5 x 3.25 x 25.25 = 1.26 cuft
Leaves 5.1 cuft. Where is that 1 cuft going?
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
You are tuned lower than your spec, actually is:
Vb = 4.777 cu.ft
Fb = 33.406117 Hz
Change the width of your port to 23 in.
Vb = 4.943 cu.ft
Fb = 30.8059807 Hz
If I go lower will compromise you port area, I am assuming a single 15" sub displacement. With dual 12" will be around 31Hz, if you want a better estimate state what subs you are using.
sorry .. im usuing a 9515 DD strapped to an AQ 2200.. sorry bout that
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
Who cares!!!
I think he should. If he has too much port the box could start sounding like crap. And start to decrease spl substantially.
You are confused.
Current system:
Previous systems:
Why do you want a 30 hz tuning???? that sub can play WAYYYY below tuning frequency, specially on that big ass box, if you still want to tuned it lower, just shrink the port area a little bit, that sub can still play strong as hell with around 55 SQ of port :)
Who cares!!!
You are confused.
x3!!
  • Who's Online   1 Member, 0 Anonymous, 2302 Guests (See full list)
