Need help with box
Gonna be running a pair of 3512's in my trunk off a Soundstream 2500 and trying to figure out what size box to run. I'm tuning to 34Hz but need help deciding on volume....right now i'm leaning towards 4.5cu.ft. Suggestions?
Not gonna be competing, this is just for daily.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
seems right to me. mine is in 2.5 cubes and it has issues with some really low notes. then again it is on 2k by itself so you shouldnt have issues
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Here are the specs:
SPECIFICATIONS
Series 3500e
Voice Coil Diameter 3"
Magnet Weight 240 oz
Power Handling RMS/Peak 1200/4800
Suspension Travel 80 mm
Nominal Impedance D1.5 Ohm
DC Resistance D 1.5
Model 3512e
Rec Box (cubic ft) 2.5
Port Area (sq in) 40
Port Length (inches) 22
Woofer Diameter 12"
Free Air Resonance 32 Hz
Qts 0.36
Qes 0.39
Qms 4.81
Vas 40L
Sensitivity 89 dB
Shipping Weight 35 lbs
If you need halp with the design let me know you maximum dims or use the Torres.
I had a 2512 in a 2.25cu.ft. box tuned to 34hz on 1500rms and it banged! I had heard some crazy big box recommendations and just wanted to be sure I'd be ok. Oh yeah, just using a single 6" aero, still good?
Well, if you are right then 40/2.5 = 16, the maximum for slots, 13 is the maximum for aeros so 2.5 x 13 = 32.5.
If you are willing to compromise a single 6 aero will do for one sub so two ports for 2 subs would be minimum. which leads to 45.9 in long each to get to 34Hz!
A slot port based design would be better for this design. if you have the space.
Damn....Gonna have to check the port mach and see what it says.....I hella want to use an aero but not if its gonna sound like ass
  • Who's Online   1 Member, 0 Anonymous, 1144 Guests (See full list)
