30Hz.wav Posted January 25, 2012 Report Share Posted January 25, 2012 Building this box for a friend, he currently has it in a sealed box. This is going in the back seat of his truck, but we are keeping the 1 seater up and letting the box sit up so it can fire port up, and subs front. I have it tuned to 34Hz, and Net Volume of 3.49. The JL Audio Website recommends 1.75 cubit feet for a ported box on each sub. http://www.jlaudio.com/12w3v3-4-car-audio-w3v3-subwoofer-drivers-92154 Can anyone let me know if the box checks out ok, wanna start building this asap. Thanks! Any help is appreciated. Here's what I came up with: Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted January 25, 2012 Report Share Posted January 25, 2012 joo forgot woofer displacement This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
Joe X Posted January 25, 2012 Report Share Posted January 25, 2012 0.071 cift per sub. Also why the side port, you will need like 4-5" of free airspace in front of the outer end for it to stay tuned. Link to comment Share on other sites More sharing options...
30Hz.wav Posted January 25, 2012 Author Report Share Posted January 25, 2012 joo forgot woofer displacement dammit, your right lol. I typed it in, and it didn't change much. It set me back to 3.35 net volume. Not too worried about that. Link to comment Share on other sites More sharing options...
30Hz.wav Posted January 25, 2012 Author Report Share Posted January 25, 2012 0.071 cift per sub. Also why the side port, you will need like 4-5" of free airspace in front of the outer end for it to stay tuned. In my previous post, I mentioned that port will fire up and subs face forward. Gonna sit in the back of a truck where the 1 seater flips up. Link to comment Share on other sites More sharing options...
Sergeant_Skyrim Posted January 25, 2012 Report Share Posted January 25, 2012 Says your port will bbe 18.5x2.5...seems like you might have issues with port noise with a ratio like that Build in progress Link to comment Share on other sites More sharing options...
Joe X Posted January 25, 2012 Report Share Posted January 25, 2012 Right I missed that part sorry. 3 things should be also noted: 1) as pointed out the H/W ratio of the port should be <= 9. 2)the sub cutouts seem near check for overlapping of the external duameters (12.5 in) 3)also bracing / double baffle are options to consider. Link to comment Share on other sites More sharing options...
