Title pretty much says all. I'm gonna be putting 2 15's in a box running them off mono amp. Box will look like what is the default image on the RE audio box part of the website. Question is when doing so, obviously the cubic feet will get doubled for 2 subs. But how does having 2 subs effect the port? What do I change with the specs in order to tune it for 2 subs?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
Double the area and then calculate the required length.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
so basically if i was tuning it to lets say 30hz with the re audio box calc, wouldnt all i have to do is just adjust the port to 60 hz? or is my logic backwards?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
umm, you want the port to be more of in the 30-38hz range with 14-16 sq inches of port per sq foot of box for a slot port and i think it was 9-13 for aero ports
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
yea i know but it just seems like common sense if you were to double port area, in turn, youd double hz. but i think im wrong.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
If you are doubling the airspace you need to put a second port that is *identical* to the one previously used, if you want a single port you have double the area and recalculate the port length to the tuning of the previous one.
Also the last time I checked the RE calculator had obvious flaws, work with the Torres claculator wich is free and is more accurate.
Thanks for the help guys. :drinks:
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
