How To Do The Big 3: Tutorial
Guest MegaloManiac
Hey i put my block to chassis ground and ran it from my alt mount to my negative terminal. does this still work fine.
No, you want alt->ground (frame or if unibody to strut tower) and batt->ground (frame or if unibody to strut tower)
While informative the OP needs a massive update.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
so should i just pick a spot on my engine block and ground it to the chassis?
-2002 Impala Ls
-Optima yellow top x 2, big 3
-Pioneer 5.8" touchscreen
-Infinity 6.1 Kappa Perfect Components
-Alpine type r 6" coaxial x 4
- Audio Que hdc312 x 2
-Mb quart 4 ch. x 2
-knu wire
-Audio Que 2200w amp
- db electric 220amp alt
Chassis? I didn't say anything about chassis bro, read what I said again.
If you can't reach the strut tower (the bolts coming up through the wheel well) then you want chassis->ALTERNATOR and chassis->battery.. When they say "engine" that should really be as close to the alternator as you can get rather than just some random spot on the motor.
The OP is informative but wrong.
  1. Best options is FRAME->ALT BOLT (or alt ground if the alt has a bolt on it for that), FRAME->BATT (negative), and then ALT->BATT (positive)
  2. Second best is STRUT TOWER->ALT BOLT, STRUT TOWER->BATT (negative), and then ALT->BATT (positive)
  3. Third best is CHASSIS->ALT BOLT (or alt ground if the alt has a bolt on it for that), CHASSIS->BATT (negative), and then CHASSIS->BATT (positive)
#1 is only an option if you have a full frame.
Pioneer X8500
2 270a Mechman Alts
Question I have the big 3 done is it safe to take off the old wires from the alternator to the battery and the old grounds cause on my big 3 I have 2 wires going from battery to alt the stock gauge wire and the 0 gauge and then the stock battery ground to block and 0 gauge to block lol.
DUDE DID ANYONE NOTICE THAT HE SCREWED THE FUSE HOLDER INTO THE BATTERY!! SCREWED INTO THE SIDE OF THE BATTERY! WTF?!?!
Go look again... Its into the battery box that keeps engine heat away from the battery.
Check your screen resolution.... <-------- :shok:
Does this smell funny to you? Its your sister :roflmao:
thanks for the help
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
ok so i looked through this thread and i didnt see anything about how to do the big 3 if your battery is in the trunk my car doesnt have a battery under the hood so how do i do the big 3
  • Who's Online   1 Member, 0 Anonymous, 816 Guests (See full list)
