How To Do The Big 3: Tutorial
Guest MegaloManiac
I understand... but as of right now i have no battery in the engine bay. they are all in the bed. i'm debating whether to put a d375 under the hood cause it is really tight under the hood. so would that mean i will have to run the wire from the front to the rear then?
Im assuming your battery's are grounded to the chassis/frame in the bed? I would just upgrade the engine to chassis/frame until you can get some money to run a 1/0 or 2/0 from the alt bracket all the way back to the rear batts. No need to find room to put a batt up front.
Edit-just make sure you find a good solid spot to ground to the chassis/frame and always make sure you ground down to bare metal.
stupid double post on my phone lol
I would do the same thing as sprkn_ranger is suggesting
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Sounds like you have an issue with something not shutting off if your not playing and the truck is sitting and draining your batt.
my understanding of grounding to the engingblock tk batt was for a better ground from the alt.
please correct me if im wrong
Yea your right, the alt is grounded through the engine block from the alt bracket (if that makes sense) and that's why you upgrade the ground wire from the block to the chassis. You can also run a wire from the alt bracket to the chassis/frame as well.
Here is that diagram if anyone wants it:
  • 4 weeks later...
so if you have multiple batts would you do it for all batts or how would you wire several batts because i get how to do the BIG 3 and as soon as i start my new build im saving for i will add this but i want at least 2-3 batts and 2 under the hood. i know all the batts are going to connect to the charging batt but would i do BIG 3 on all batts or how would i wire several batts? (asked same thing twice sorry)
you are fusing the wire what is your wire rated at.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
My big 3 for the 1999 Camry XLE v6
Top left corner Engine to Ground
Top right, Negative on battery to ground
Battery positive to Alternator
  • Who's Online   1 Member, 0 Anonymous, 1432 Guests (See full list)
