How To Do The Big 3: Tutorial
Guest MegaloManiac
how do i do the big 3 upgrade using a digital battery terminal only for the positive with my battery being under my backseat? i have a 2001 buick lesabre custom.
You run the same cable the same way just longer
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
ok I'm new to this if you could give me a step by step set up or a diagram I would appreciate it. I have side post battery with the option of top post which is what I want to use.
Read the very first post in this topic and do what it says. Doesn't matter if your battery is one inch away from your alt, or if it's in the rear of a truck bed. All the battery placement affects is the length of wire needed and the difficulty of running said wire.
  • 2 months later...
I have a question on this . I have a 73 C10 and my power from battery goes straight to starter and then to alternator. The only ground I see goes from battery to engine block. I just ordered the xs big 3 kit I want to clean all of this wiring up . All of the instructions say go from battery to alternator . Does anyone have any thought on running the current way or going from battery to alternator ?
  • 7 months later...
On 4/23/2014 at 11:05 PM, AvionicsTek said:
) Running your wire from the alternator all the way to your battery and then putting a fuse holder there defeats the purpose of the fuse all together. Again... The fuse is there to protect the wiring, so it doesn't make much sense to put it at the other end of the wiring in which it is supposed to protect. The fuse holder should be as close to the alternator as possible, because the alternator is the source of power. If the alternator spikes, it will blow the fuse, almost instantly, a few inches from the alternator, and no harm should come to the wiring. Otherwise, with the fuse being that far from the alternator means that if the alternator spikes (and you're not using appropriately sized wire for the highest of possible loads), it will burn the wiring, melt the fuse holder, and the fuse will probably still be intact after the fire department has left the scene. This is the same reason we put fuse/breaker, for amplifier power cables, are near the battery, and not near the amp. The battery is the power source (or buffer, rather) for the amp, and should the amp spike and overdraw current, it will blow the fuse or trip the breaker at the battery, and leave the wiring intact. So, in short... Cable terminated to positive post on alternator, directly to fuse/breaker close to alternator, then routed from fuse/breaker and terminated at battery's positive post, then wiring from battery positive post is terminated to fuse/breaker close to battery, then wiring routed from battery fuse/breaker and terminated to distribution blocks (near capacitors, amps, etc.), then routed from dist. blocks and terminated at capacitors, amps, etc. DIRECTLY after every power SOURCE (alternator or battery), there should be a breaker/fuse to protect the wiring from that point to the next.
is this accurate? ^^^^   sounds like it
this is my first build, i have been waiting 4-5 years to have this done
95 chevy 2 door tahoe 5.7
Xs power d3400
Singer 275amp alternator
Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders
Sundown SAE-1500d
Mbquart onyx OA800.4
Stinger 4400 series RCAs and stinger volt meter
Fi Q NEO 18, 7.5 cubes tuned 32hz
Pioneer MVH-X690BS H/U
Kicker CSS 6.5 comp sets in front doors
Kicker KSC 4x10 coaxials in rear
GTMAT and FAT MAT deadner
Xenon 10k Blue HIDs
What? A fuse at the alt? Ok then you need two because you need one at the battery too. Sorry I stopped reading after that.
Pioneer 80PRS
  • 2 years later...
Hey guys sorry to revive an old thread but I have a question. For the engine to ground, it says to grab a bolt from the engine and ground it to the frame. Does it matter which bolt on the engine it is, or is it better if it’s from a certain part of the engine (timing cover, actual block) etc?
  • 1 month later...
  • 5 months later...
  • Who's Online   1 Member, 0 Anonymous, 1866 Guests (See full list)
