temporary glue joint repair?
baaudio
so my 18 just had the cone tear from the coil. it seems like a pretty clean failure. but is it okay to glue this with some more ca til i get my recone?
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Its worth a shot. But don't over do it cause the extra weight is not good. I had a re sx 18 that did the same thing and I used apoxy from the hard ware store and it worked fine. The subs still going strong. My freinds got it now and had no problems at all and he hammers it everyday
glue the crap out of it
Hammerdown... 1%
Any recommendations on what glue? I know some guys use CA or epoxy. But what's gonna work best
Team NWSPL
baaudio Build Log
i used 2 part epoxy from harbor freight, the stuff that holds 1200lbs per inch..
i had a aq hdc3 18 that had a failed triple joint and ripped spiders.. epoxyd that bitch up and finished killing it
ca glue will work also.. ( i order fi's glue they sell on their website)
  • Who's Online   1 Member, 0 Anonymous, 1369 Guests (See full list)
