Hello guys and girls! The time has finally arrived to begin Stage 3 of my build, the Kickin' Cruiser. If you haven't seen any of the first two stages, you can catch up HERE.
The car is a 2002 Chrysler PT Cruiser that I bought a few years ago, and fell in love with ever since. Best car I have ever owned!
And a while back, I decided to split the build into stages, so that it wouldn't seem so over-whelming, and so it would be easier to navigate through. So here is the plan for the different stages:
Stage 1 - Initial instal
Stage 2 - Fiberglass and accessories (Learning Stage)
Stage 3 - Dash, doors, and a 4th order wall. (Time to get serious stage!)
Stage 4 - Rims. body, and paint
Stage 5 - Engine/ drive-train (performance mods)
For this stage, we will be focusing on the interior of the car. We will build new custom door panels, dash panel, change all of the interior color from light brown/ dark brown to grey/ black. I'll also be Installing new carpet front to back, as well as building a new headliner. We will finish it off with new seats. Basically the whole inside of the car is getting a make-over!!! Oh and how could I forget? I'll be building a 4th order wall for 4 Skar VVX 15's (v.1), to run off a DC5.0K. Goals are 50's on music, and nasty hair tricks on demand. So here we go!!!!
*** This post will be updated periodically ***
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
Okay, so first order of business will be the door panels. This is what they look like to start with.
This will be going into each door!
8" slim mount subs
2 - 6.5" component speakers
And a set of 5.25" to finish them off. So each door will look something like this:
So first thing we need are some MDF rings! This makes it way easier!
And now we got some rings!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Okay, so next it's time to get some wood. So let's see what the local hardware store has.
There we go! Need some of this.
And about 5 sheets of this
So then I had to cut down the sheet of 1/4" into 4 - 2ft x 4ft pieces
So the next step is to separate the inside of the door panel from the outside. This was no fun at all!!! Took me several hours with a heat gun.
Plastic welds SUCK!!!
One down, one to go
No turning back now!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
So then I use the inner piece as a template to cut out the new piece
Also, had to clean up the inside of the outer panel.
And this is what I was shooting for!
Something like this, except with 5.25's instead of tweets up top.
And that is where I quit for the day! Tomorrow, I'll figure out how to mount the new panel to the door, and how to keep the armrest while doing so!
Thanks for checkin' out my work! Stay tuned for much, much more to come!
EDIT:
This attempt failed, click here to skip ahead to the successful attempt :)
However, if you do, you will miss the dual front battery install, w/ custom busbars, as well as some sound deadner and a few other little things.
Your choice!
Link to current doors, starts on page 4
http://www.stevemeadedesigns.com/board/topic/132828-kickin-cruiser-stage-3-door-panels/page__view__findpost__p__2013367
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
this could turn out well
kinda convenient that the whole middle of your door comes out lol
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Yeah that door panel coming out makes room for all kinds of mids...midwall on each door!
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Thanks fellas! :drinks: Yeah these doors have been on my mind for a long time, since I seen what lowpt did with his doors. They are perfect for upgrades! And yep exactly... mid-wall on each door!!! 8)
After sleeping on it, I decided to go ahead and order another ks component set, this one 5.25, to go above the 8's in each door. I think it will flat out look better. They will be here wednesday, so no real hold-up. :clapping:
So I'm going outside now to start mounting the new panels to the doors, and figure out a way to make it removable. Also, I should have some packages in today. :woot:
Updates coming later! :good:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Purple,
Hello, it was a pleasant surprise to see you back at it. Of course it goes without saying that everything is looking stellar.
The doors are going to look mighty fine judging by the start.
Keep up the good work, as usual, I'll be watchin'.
Oh and how could I forget? I'll be building a 4th order wall for 4 Skar VVX 15's, to run off a DC5.0K. Goals are 50's in music, and hair tricks on demand. So here we go!!!!
:o! welcome to the dark side >:]
i see you switched the idea from dc subs to skar, can i ask why? or should i delete the question?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Purple,
Thanks man! And as always, I glad to see ya still around! :drinks:
Thanks! And yeah, it's totally cool to ask!
The reason I am going with Skar atm instead is because of two reasons.
First, I have seen a lot of good things from the new Skar VVX subs, especially on the lower end, if you know what I mean ;)
Second reason is that Kevin, the owner of Skar, made me a deal I simply couldn't pass up. So instead of running three 12's this year, I get to go ahead and build my dream set-up. A 4th order wall, w/ 4 - 15's. How could I resist? If I want, as long as I build it correctly, I can always swap the subs out for some DC XL 15's, and just add more power. But for now, I pretty much had to do this.
And thanks for checking out my build!
I'll be updating it pretty much daily from now on, until she's finished.
Which does take a little extra time, but it's all worth it! Hope you guys enjoy! :drinks:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
  • Who's Online   0 Members, 0 Anonymous, 9371 Guests (See full list)
