Okay so I finished my box and it sounds good got good window flex door flex adn trunk warps like a tornado xD anyways the sub is upfirign and port is firing into passenger side trunk lid,, I have plenty of sounds deadener jsut need to know where to apply it, since its upfiring the mustang has the rear deck with all the huge speaker holes in it so shuld I deaden that or will i lose spl? also what about bed liner before I stick this stuff down would it help if I sprasy bedliner the whole thing?
All over the trunk and trunk lid
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
no amount of deadener will stop that trunk from moving with a sub firing towards it
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
lol the sub is directly under the rear deck like it fires up into the cabin :D and ya i no beast mode is beast mode xD but will spray bedliner help? and im already replacing the weatherstripping
the only thing that will help is bolting the trunk shut
or sealing off forward
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Line the whole trunk with it. It's not going to stop it completely but it will definitely help and make a noticeable difference. Do the doors too if you have enough.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
IMO a waste. Which deadener are you using? The point of CLD is to diminish resonance, which can be accomplished with a single layer of 25-50% coverage in the middle of a panel.
true for a flat panel
which the trunk lid is not
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Yup, in that case it should be even easier.
