727Designs Posted January 31, 2012 Report Share Posted January 31, 2012 i say back off to the clip. the dd1 is to dectect distortion, not clipping. so even with a soft clip ther might not be distotion. one would say distortion before clipping. but who knows. either way even if it doesnt distort, there can always be a soft clip you wont be able to see without a good oscope. if you trust your clip indicator, and the dd1, i say jus set it prior to the dd1,there for you be distortion free and clipp free from what the indicator is reading From my understanding a clip light doesn't necessarily measure clipping to begin with, they are set with a certain input rail voltage that causes the light to cut on when it's exceeded. I could be wrong, and if so someone feel free to correct me. Quote -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD- Link to comment Share on other sites More sharing options...
eltico7213 Posted January 31, 2012 Author Report Share Posted January 31, 2012 so from what i'm hearing, i should just forget about my clip light.? more details, the h/u is a Pioneer AVH 3300BT, sub amp is a DD M3a, and sub is a DD 9512 D1 wired to .5 ohm. Quote Link to comment Share on other sites More sharing options...
Decaf Posted January 31, 2012 Report Share Posted January 31, 2012 i say back off to the clip. the dd1 is to dectect distortion, not clipping. so even with a soft clip ther might not be distotion. one would say distortion before clipping. but who knows. either way even if it doesnt distort, there can always be a soft clip you wont be able to see without a good oscope. if you trust your clip indicator, and the dd1, i say jus set it prior to the dd1,there for you be distortion free and clipp free from what the indicator is reading distortion comes from clipping, and can be present before clipping. two separate things. the clip light on the amp is lighting when rail voltage meets output voltage, so if you play a song louder than the track you used to set sub amp gains, you will clip/distort. From my understanding a clip light doesn't necessarily measure clipping to begin with, they are set with a certain input rail voltage that causes the light to cut on when it's exceeded. I could be wrong, and if so someone feel free to correct me. Quote Link to comment Share on other sites More sharing options...
Lbox88 Posted January 31, 2012 Report Share Posted January 31, 2012 ^listen to decaf. Quote UBL | Build Log Link to comment Share on other sites More sharing options...
eltico7213 Posted January 31, 2012 Author Report Share Posted January 31, 2012 i say back off to the clip. the dd1 is to dectect distortion, not clipping. so even with a soft clip ther might not be distotion. one would say distortion before clipping. but who knows. either way even if it doesnt distort, there can always be a soft clip you wont be able to see without a good oscope. if you trust your clip indicator, and the dd1, i say jus set it prior to the dd1,there for you be distortion free and clipp free from what the indicator is reading distortion comes from clipping, and can be present before clipping. two separate things. the clip light on the amp is lighting when rail voltage meets output voltage, so if you play a song louder than the track you used to set sub amp gains, you will clip/distort. so you're basically saying that the music is most likely playing louder than the test tone from the dd-1.? i used track 5 (40hz, -10db) to tune it.. should i use the -5db track instead.? Quote Link to comment Share on other sites More sharing options...
Decaf Posted January 31, 2012 Report Share Posted January 31, 2012 i say back off to the clip. the dd1 is to dectect distortion, not clipping. so even with a soft clip ther might not be distotion. one would say distortion before clipping. but who knows. either way even if it doesnt distort, there can always be a soft clip you wont be able to see without a good oscope. if you trust your clip indicator, and the dd1, i say jus set it prior to the dd1,there for you be distortion free and clipp free from what the indicator is reading distortion comes from clipping, and can be present before clipping. two separate things. the clip light on the amp is lighting when rail voltage meets output voltage, so if you play a song louder than the track you used to set sub amp gains, you will clip/distort. so you're basically saying that the music is most likely playing louder than the test tone from the dd-1.? i used track 5 (40hz, -10db) to tune it.. should i use the -5db track instead.? yes, the red light will blink less with that setting Quote Link to comment Share on other sites More sharing options...
Moblaw Posted January 31, 2012 Report Share Posted January 31, 2012 Just ignore the amps clipping light if you used the dd1 then your fine Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted January 31, 2012 Report Share Posted January 31, 2012 buyt a sharpie. color over that stupid light. set wtih dd-1. have fun. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
eltico7213 Posted January 31, 2012 Author Report Share Posted January 31, 2012 Well im going to follow decaf's advice. I'll let you guys know how it goes! Quote Link to comment Share on other sites More sharing options...
TonyD'Amore Posted February 18, 2012 Report Share Posted February 18, 2012 How did it go? Quote Link to comment Share on other sites More sharing options...
