Most of the time people want money to design a box. I would help if i could but i cant design
im not sure we got your point in the first 6 posts....
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Here you go, Double baffled, flush mounted, sealed box
Hope this helps.
Edited by carshateme
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Seriously you need this designed?
This drivers optimize according to RF at 1.6 cuft each so Vb = 3.2 cuft.
Each driver has a displacement of 0.107 cuft so total displacement is = 0.214 cuft
Enclosure Specifications:
Vb = 3,3 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 17 in
External Width = 36 in
External Depth = 13,5 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 36 x 17
Left & Right Sides = 11 1/4 x 15 1/2
Top & Bottom = 36 x 11 1/4
The extra 0.1 cubic feet you can use for some crossbracing you may want to do (front to back). There is a double layer baffle which also acts like bracing.
Left and right sides are 12" not 11.25"
Vb = 3,3 ft^3
Cut List:
Wrong. It says 2x front (3 pieces total)
13.5 - 2.25 = 11.25
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Ok, now I see where you got it from.
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
