Installing a LOC in a BMW with HK
midlandtech
its an 04 E46 warranties up but I was hoping to keep the stock HU and HK speakers and just add the sub for a little more low range
Well if I am no mistaken you can still put in a aftermarket HU and still have your stock speakers work. Just need to get a harness for the HU.
oh you have factory amplifiers in the car already?! yea like baaudio said the PACL SNI-35 is only rated for 35rms input. I didn't have amps in my car so it worked for me. In your case either check out the Audiocontrol LC-2 for sure. or maybe remove stock amps
completely and go after market completely?! it would be easier. A clean OEM integration takes some careful thought!
I would not reccomend that, seeing as you need your stock HU and amp to keep chimes and updates for BMW to check your car. That link I posted should help you out a lot.
i mean keep the H/U but everything else after the source unit to be after market.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
true... maybe I should look into that as an alternative option if I can't get the LOC to work
Ride: 2004 BMW ZHP Performance: intake, exhaust, shark injector, light weight clutch and fly wheel Exterior: 35% tint, Hamann front lip, smoked tails, smoked corners, smoked side markers, 3000K fogs and Headlights, angel eyes, rebadged, and blacked out kidney grills Audio: stock HK system 2 orion xtr 10's ported at 33 Hz
Let me clear this up for you.
Real simple.
First of all the stock subs under the front seats are bandpassed at 70hz.
Secondly, you have full range 20-20k right at your headunit
The amp only drives a few of the speakers. The deck actually runs the front and rear components.
So. Blue twisted pair at radio
That should do it for you.
Sorry for the 35posts about your "Cheap loc"..
cheap or not it sounds good! but i agree! directly behind the head unit is easiest to access wires and you know 100% what signal you are getting.
BMW M340 xDrive
Real simple.
is that for a E90? in my car (E46) HU sends audio signal to an amp located on the left side of the trunk which then sends wires to the components in the cab of the vehicle. There was a second amp specifically for the rear deck mounted 6x9 subs which was attached to the left sub and fed the 2 speakers I removed that amp when I removed the subs. the wires I tapped into (amp on the left side of the trunk) were yellow/black twisted with brown orange and blue black twisted with brown orange
how did i know ray would know the answer to this off the top of his head.....
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Cause i do this for a living.
Thats why n8
I would have said E90 if i meant that.
Sorry for any confusion on your part
  • Who's Online   0 Members, 0 Anonymous, 720 Guests (See full list)
