Lbox88 Posted February 3, 2012 Report Posted February 3, 2012 (edited) 2 dual 4 ohm, and 4 cubes total after displacement. You can get torres box calc out of my sig below if you haven't already. Edited February 3, 2012 by Lbox88 Quote UBL | Build Log
pa-pa-platypus Posted February 3, 2012 Report Posted February 3, 2012 dual 4 ohms wire down to 1 ohm..and he meant 4 cubes total (i hope) Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
baldwin3m Posted February 3, 2012 Author Report Posted February 3, 2012 I can run wire and all that, the biggest system i have installed was 2 jl w3 12s and a kenwood 1800watt amp. so i know the basics of car audio but not everything i would like to know! Quote
c0dy Posted February 3, 2012 Report Posted February 3, 2012 The box should be 4 cubic ft total or per each sub? cause i thought 2.25cubic ft would be good per sub... im probably going to go with the AQ1200D just cause im inexperienced at the time. And what would be better to run with the AQ1200 dual 2 ohm or dual 4 ohm? According to their website, that amp is good at 1 Ohm, so I would run two dual 4 ohm subs wired in parallel (each sub bringing a 2 ohm load, bringing a 1 ohm load overall to the amp). Quote RF 12" P3D4 RF 300.1 ~ BC: 430w 4 x Infinity Reference 5012i B-Quiet Extreme
KillaCam Posted February 3, 2012 Report Posted February 3, 2012 Yes i will definitely have to have someone design a box for me and maybe even build it, willing to pay for the box and s&h. but that probably can be discussed later. also, what do you plan on doing for your front stage? ^^what do you mean by that? like under the hood and with my headunit and all that? Man the front stage is your mids and highs, door panels, A pillars. Yeah I agree with the above stay with they 1200d. Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
baldwin3m Posted February 3, 2012 Author Report Posted February 3, 2012 yes i hope 4cu ft total too! haha that would be a huge box! What do you guys think about my battery and alt? Im still running the stock ones, do you think i need to upgrade them anytime soon? if so are my batt and alt in the build log okay or would anyone recommend anything else? Quote
baldwin3m Posted February 3, 2012 Author Report Posted February 3, 2012 Man the front stage is your mids and highs, door panels, A pillars. Yeah I agree with the above stay with they 1200d. What are A pillars? and im running 2 memphis tweeters, 2 memphis 6.5" and 2 memphis 6X9 with no amp. Sorry for all the noob questions Quote
KillaCam Posted February 3, 2012 Report Posted February 3, 2012 These are the pillars. Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
Lbox88 Posted February 3, 2012 Report Posted February 3, 2012 You should be fine I would think with the stock alt but make sure to do the big 3 and if you have a standard lead acid batt, it's good to replace them with a decent agm. Quote UBL | Build Log
miniSPLlancer Posted February 3, 2012 Report Posted February 3, 2012 I just sold my SA-12's, had them in several boxes. I did iirc, 4ft3@33 on Credcendo 2000, those subs are made so well its stupid, I had then in 3ft3@43, a 4th order@28. Those play well no matter what. I personally would tune low, my opinion. 3.5ft3@33ish, might wanna go 4ft3 if only running 1200 watts, once you get the 2200 I'd go 3.5ft3 Quote 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
