I currently have two 12" Kenwoods in a sealed box at 500rms each. The system is in a Tiburon and I recently removed my rear seats and essentially made the entire back area into a flat surface. With the extra room I want to add in two more 12"s. I would be using the exact same subs and another identical amp for the addition. What I wanted to do was build a new ported box for two of the subs and then another sealed box for the other two. I want to keep nice tight bass that I have with the sealed box, but also have more punch and pressure like I would have with a ported box.
http://i1356.photobucket.com/albums/q722/Joey_Medders/8c5ab882-507f-4d37-9a86-1c34d3ccec2e_zps1dd7c0f1.jpg
2007 Yamaha FZ1 - Full Yoshi system, Airbox mod, BCM filter, PCIII, PCIII quick shifter - [email protected]
2005 Hyundai Tiburon GT - I/H/E Crower Cam, NGM reflash - [email protected] (slow as hell) - audio car (142db) - RIP December 31st 2012
Pioneer AVH-P34000BH
Hifonics ZRX3000.1D
2 Fi BL 15s - dual 1ohm - cooling, flatwind coil, daily
9 cube ported @34hz
Hifonics ZRX1000.4
RE Audio XXX6.5C front doorPyle PLG69.4 rear panels
KnuKoncepts KCA 0/1 big 3 & 2 runs to back
KnuKoncepts RCA/speaker wire/distro
XS Power D3100 under hood
I don't see a problem with it, although it'd sound a lot better in a ported box all together. *NO QUOTING*
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
i see no issues there. should put the sealed box upfront and the ported box in back then swap it around to see what placement for the boxes soundes best to you.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
That's that I had planned on. The ported two would be under hatch with the ports facing the back. Then the sealed box closer to the back of the front seats. Here are two pics of the box in sketchup. The first pic is of the box from the back of the car, the second from the front of the car.
Edited by osage
Hifonics ZRX3000.1D
9 cube ported @34hz
Hifonics ZRX1000.4
I think you have a misconception that porting will make your bass sloppy. It is not the case. port all four be happy.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Afternoon bump
Hifonics ZRX3000.1D
9 cube ported @34hz
Hifonics ZRX1000.4
did you read the post above you? your idea of the sealed vs port is all wrong. depends on what you want out of it. my 18 is tuned in the lower to mid 30's and i still have my tight bass as you called it. i can throw on some metal and all is good. may not have the output of a higher tuned box but it plays very well on heavier music. the difference is the sealed box there is no tuning as the ported box you would tune your port. build a ported box for just one so you dont waste a lot of wood and see how it performs. you will be much happier with all 4 ported than 2 sealed and 2 ported.
2015 silverado crew cab
nothing atm but soon...
Alright, thanks for the input. I'll give it a shot and see how it all turns out.
Hifonics ZRX3000.1D
9 cube ported @34hz
Hifonics ZRX1000.4
goodluck man!! all 4 ported WILL sound awesome and if designed right give you that tight musical bass you want
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   0 Members, 0 Anonymous, 1755 Guests (See full list)
