That's kind of like saying 12" woofers are not good for car audio because they keep blowing.
The trick is to choose the correctly sized breaker for the application. A breaker has a simple task - prevent a fire without becoming a bottlekneck. Choose the incorrect sized breaker and you will trip it often. Choose the correct sized breaker and it will trip when the cable connected to it becomes shorted.
We offer both high quality ANL Fuse Holders and Fuses (up to 500 amps) and Manual Resetting Circuit Breakers (up to 200 Amps). It all depends on your application. I'm not a fan of "bargain" stuff here because they will be a bottleneck.
I have always heard that circuit breakers are less and less reliable each time they are tripped, is this false? I respect your knowledge and if I'm wrong I'd like to know.
Edited by sprkn_ranger
of course it's true. it's akin to a spring that gets weaker each time it is compressed or stretched. The real question is NOT if they get less and less reliable each time they trip, but rather why do they keep tripping???
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Most circuit breakers are "thermal snap" type which take too long to open the circuit, making them unsuited for protecting electronic equipment.
I didn't think I was giving out false info...maybe I should have worded my first post better. I dunno, the way I see it is if set up properly, a fuse will do the exact same thing at a lower price and if the install is done where fuses keep popping then a circuit breaker is NOT the answer.
Your fuse shouldn't keep popping. If you have fuse or circuit breaker problems then you don't need to worry about which one to use, you need to fix the problem.
F150:
Stock :(
Processor: DSR1
Exactly...that's what I was getting at. Lol
well fine then. we'll agree to agree!
lol
lol i believe ill just go with fuses just because there will be no second guessing
Edited by ZachAdams
-Zach- '88 K5
- '01 cbr929rr
  • Who's Online   0 Members, 0 Anonymous, 2898 Guests (See full list)
