beat2deth Posted February 8, 2012 Report Posted February 8, 2012 tried turning the radio back on? stupid question, but i had the same issue when i first put in my d3400, and it was cuz i completely forgot to turn my hu on :x Quote
Sid420 Posted February 8, 2012 Author Report Posted February 8, 2012 the head unit was one we were listening to some cd's while tring to fix it. Quote
pa-pa-platypus Posted February 8, 2012 Report Posted February 8, 2012 you were working on ur electrical with the car running?! oh and check to make sure theres not a subwoofer on/off thing some units have that..hadn't thought of that Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Guest Posted February 8, 2012 Report Posted February 8, 2012 He can't say that it can't be something that he didn't check. In regards to the remote wire Quote
varietyguy Posted February 8, 2012 Report Posted February 8, 2012 run a jumper from the battery input on the amp to the remote input. (remove remote wire from amp before you do this.) Get a DMM and check inputs. Quote 1992 Mazda 323 http://www.stevemead...323-wall-build/
carshateme Posted February 8, 2012 Report Posted February 8, 2012 Umm...you had your car battery still hooked up while you were working on it....sounds like you might've shorted out your fuse on your positive wire if you hit the frame... Quote New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Sid420 Posted February 8, 2012 Author Report Posted February 8, 2012 okay. the car was one when we were looking at it but when we started un hooking things we turned it off. and you mean run a small wire from the power input to the remote input? Quote
Lbox88 Posted February 8, 2012 Report Posted February 8, 2012 yes, but make sure you take off the remote wire that comes from the HU first. Quote UBL | Build Log
