summah boy Posted February 8, 2012 Report Posted February 8, 2012 i found a twin turbo for my 92 firebird but i want to know if i will be getting everything i need can somebody list all the things before i buy it?
OrionStang Posted February 8, 2012 Report Posted February 8, 2012 Do you know how long the parts list is for a complete turbo kit? LOL SMD Super Seller My Feedback Thread
carshateme Posted February 8, 2012 Report Posted February 8, 2012 Lmfao..wow, yeah, orion is right xDD My friend has a 87' firebird, just put a 450 small block in it...we had to buy so much shit for it...it wasn't funny...like half of the car shop was filled with boxes. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
ZachAdams Posted February 8, 2012 Report Posted February 8, 2012 lol.. what engine is in your fb? -Zach- '88 K5 - '01 cbr929rr
carshateme Posted February 8, 2012 Report Posted February 8, 2012 Turbo (generally a T3 or T3/T4 will do) Wastegate (Internal or external) Manifold Turbo downpipe Flange Bolts for turbo and downpipe flange Downpipe Braided oil lines with fittings 2.5" Pipe for charge pipes Connectors and clamps for pipes BOV and flange (Again DSM would be cheap ~$50, will hold 19psi with the top crushed) FMU (I'd go cartech adjustable personally) go with an SAFC 2 Bigger Injectors Bigger Injectors (DSM450's would be an excellent idea) Inline/In tank pump Boost controller (I'd go Greddy Profec) MSD-DIS 2this should read MSD BTM TB Plenum Lots of misc vaccum hose Rubber Fuel lines for FPR Oil and oil filter (for the obvious reason) Gaskets Gasket sealer Air filter Intercooler (optional, but worth it) Some spare metal brackets for custom mounting the Intercooler Misc bolts (self tapping), and Nut/bolt combos Gauge pod Boost Gauge, EGT gauge (optional but smart to have one) (If you have a profec boost controller the boost gauge is unnecessary as its built in) , Heres your list New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
rocking.that.eclipse Posted February 8, 2012 Report Posted February 8, 2012 Is there even room in your engine bay for a twin turbo?
D-train-13k Posted February 8, 2012 Report Posted February 8, 2012 i think the question is...do you know anything about engine modifications? i hope you know that using a twin turbo set up. your head bolts are going to rip right off. you should do way more research. most people dont buy bolt on turbo kits. unless they are just looking for small gains. if your buying a twin turbo set up you should just make your own pipes as well your going to have to buy bigger injectors, bigger alt, bigger fuel pump, and a laundry list of other things that your engine will need to just keep up with the added air in the your cylinders. those most likely wont come in the turbo kit. The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
ZachAdams Posted February 8, 2012 Report Posted February 8, 2012 ^ not true, low boost/stock engine setups are common. same as supercharging a stock ls1 4.6 ect.. boost is boost and any internal combustion engine can be boosted its all a question to what extent. -Zach- '88 K5 - '01 cbr929rr
ZachAdams Posted February 8, 2012 Report Posted February 8, 2012 spray>boost on a stock engine though. this is from my experience. -Zach- '88 K5 - '01 cbr929rr
OrionStang Posted February 8, 2012 Report Posted February 8, 2012 What engine is it and what condition is it in? I wouldn't boost a motor with 200k original miles. SMD Super Seller My Feedback Thread
