Do you already have a H/O alt?
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
yes i have 220 amp alternator
a 220a will NOT be enough to power 8000+ watts worth of amp.
Who makes your alt?
Depends on ohm load your wiring to... plus what your trying to accomplish.. id do a.t least 4 xs3100s I had 2 dd m4s wired to .35 each same power as aq 3500s.. I have 3 alts and 2 3100s and 2 3400 plus 8 runs and still dropped into 11s during 30 sec full tilt runs
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
