He does not have big 3 done but does have 0awg power and ground. I would have liked to wire them at I higher ohm load but I couldn't fid another way to wire 6 4-ohm single voice coil subs. Iirc I think each sub has about 1.8-1.9 cubes. Dimensions are 49w by 28 d by 21h double baffled top piece. Port is 7h by 20w by 18d on the bottom middle of the box, I used Torres' calc. If I can figure a way to
Post pics on my iPhone I will if not I'll have to wait till I get home.
LoL..I swore I read 4 12s. It may have been the plethora of numbers together lol. F it, I'm going to bed now.
10501650_10203332501847103_1859383749711
Blown
Series-parallel the drivers.
4-4-4 = 1.33
4-4-4 = 1.33
1.33+1.33 = 2.66
http://www.bcae1.com/spkrmlti.htm
how would the connection for this look?
I think i found how to do it. connect three positives to three negatives then connect remaining positives together and to the amp, and remaining negatives together and to the amp. i'll hook it up and check the reading on my DMM.
2003 Mach 1 Build
HU: Alpine CDA-9857
Sub: Fi Bl 4"VC fully loaded
Sub Amp: RF 1500-1bdcp
Highs Amp: Kicker KX650.4
Highs: Polk Audio db 6.5 comps
Epicenter
ish this configuration would br paralell/series
the diagram i found on google looks a bit different i'll try this one out first tho and measure on dmm, or maybe they end up being the same? I'll let you guys know, guy should be here any minute.
2003 Mach 1 Build
HU: Alpine CDA-9857
Epicenter
My 1000/1 is wired to .68
Never once had a problem.
Is the imp light coming on when it makes the sound? Or low v light??
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1591 Guests (See full list)
