The Black Nasty - 6 HDC4 15s + 6 Q1-3500D.1s = 162s on music!!!
The wiring looks great man. But for some reason the far right positive wires are bugging me a little bit. Can you swap there locations? Just seems like they should be swapped. Little OCD thing going on right now for me lol. Can't wait to see this up and playing.
Wondering if anyone would notice that, there is a reason for everything, with the just those two wires laying like that it is keeping it up high away from the voice coil studs once zip tied tight. It has to be that way lol.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Running each pair of amps strapped, either 1.5 ohm or .66 ohm, either one should be fine with my FAT ASS ELECTRICAL!!!!! haha
Evo X build log
Ok, I figured you wouldn't have done that on accident. I wanted to say something yesterday but decided not to. But having looked at that picture a couple of times, I couldn't take it anymore lol. It should make a little bit of noise when it is all said and done. Can't wait for vids.
formerly known as Blue86f150
this sux camel dicks
Update 10/10/12
Started on the driver side today, only got the grounds mounted to the frame, but every little bit helps get it done faster lol.
Drilled a hole thru the frame, sanded down to bare metal, then brass bolt with 8 1/0s stacked on, clears the e-brake cable by about a mm.
Going to finish wiring the amps up tomorrow.
Evo X build log
How much weight do you think you have added just in wiring and then all together.
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
Been meaning to post this too about the suspension, I couldn't be happier with the 3500 hd add a leaf and custom springworks coils, truck looks so good after I lowered the rear 1 inch on the shackles. In previous pics it looks level, WELL that is because in that pic it had 200 lbs of scrap mdf in the bed from the whole build LOL. After uploading that, here is how it sits
It was too high in the back, I had one more bolt hole in the rear shackle so I lowered it to that and got the front end aligned. Here is how it looks right now....
Perfect .5 inch of difference front to rear, higher in rear. Exactly how I want it to be. Truck rides down the road great, just doesn't stop worth a shit, but new brakes coming.....
Evo X build log
My estimate is 2400 lbs total over stock, that includes everything.
Wiring is (14) 50 ft 1/0 spools and 250 ft in 8 gauge, each one of those spools 15 total weight 22 lbs, so that is 330 lbs in just wire.
Evo X build log
That is a lot of weight over factory! Even after all the bolt-ons and tune how is the performance side of things?
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
