Pull the assembly out and file down the housing that faces the window some and re-install it and see if it still makes noise, repeat once more if you don't remove enough the first time.
EDIT: I would not recommend removing it in case your required by law to have a 3rd brake light.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
how is it mounted? some of them have slotted holes in the rear deck so you may be able to move it back away from the glass a little....if not, possibly widen the holes yourself.....this is assuming it bolts down
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
cant you just unbolt the whole brake light assembly? it would be pretty stupid if kia made it so its permanent. what if the dealer had to replace one?
ill have to look really
my corolla (completely different car obviously) has just 2 10mm bolts holding the plastic to the rear deck mounts
