you should not use that knob. its a signal booster at 45hz from 0-18db
reset with dd-1 not using bass knob and see how you like it, starting with -5db for safer setting until you stop smelling coil
whats ur model number, specifically the year
i missread when googling, you DO have a level control remote. just make sure you are not using the bass boost on amp nor heaunit
Edited by Decaf
you're fine, been a long day and i confused the boost on amp with remote, just reset using -5db and that should get rid of the problem and your system will just be a bit quieter
or continue to use -10db and just dont go full tilt volume on every song unless you know its clean enough to do so
^^10g wire is PLENTY for what hes doing
he wAS using a shitty mixtape track thats why he smelld coils.. even tho u have gains set with a dd1 it dont help any if you play clipped music lol..
decaf already mentioned that
