HDC3 12'S OR 15'S?!? Debating on which would do best.
I have prolonged my current setup too long because i have been thouroughly debating on whether to go with w AQ HDC3 12'S or 15's. Plan on putting (1) AQ 3500.1 to power both subs, they will be in an ext. cab second gen Sonoma. I have seen a couple setups involving 2 15's in an s10, although i want to get max performance from my subs. Should i do the 2 15's in a tad bit smaller box, or should i get the 12's and have them in the right enclosure?? Once this is sorted out i plan on buying the subs, just CANNOT make up my mind. Any help/suggestions/input is very welcome, pics, suggested box dims, or designs is also encouraged!! Thanks so much! ,Zach
Thank you so much! Dont quite have 8 cubes, so i'll either do a single 15 on the AQ 2200d or the 2 12's on the 3500. (if funds allow lol). Also would subs up port up work best? Saw a lot of posts saying subs forward port up? Are both pretty much the same, just a preference thing?
dont try to squeeze big woofers into an undersized box. i'd do 2 12's on the 3500. should get loud
not only are you in the wrong forum but you start a vs thread. Keep u pthe good work.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1589 Guests (See full list)
