Swordlordboy1234 Posted February 19, 2012 Report Posted February 19, 2012 So i found a focus zx5 for an unbeatable price, but i found out they have whack speaker sizes 5x7/6x8 speakers fit in both the front and rear doors... Im trying to get Crescendo audio mids for personal reasons. They have 6 inch and 8 inch speaker sizes (also a 10) again as most of u know. well my question is... Can i fit the 6'' or the 8'' in each of my doors? which would be a better fit? I understand ill have to take the door panel off and cut holes or make custom brackets ect. But i want to know what you guys think will be better in those 6x8 spots... the crescendo audio 6'' mid or the 8'' mid, and some suggestions on what would be the best way to install them. Thanks guys My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
BobbyG2 Posted February 20, 2012 Report Posted February 20, 2012 You should be able to fit the 6" fine, check the mounting depth. The 8" you'll have to do some modifications. *New vehicle and system coming soon.*
ChevyBoy95 Posted February 20, 2012 Report Posted February 20, 2012 a 6 should fit, but you want to check mounting depth, sometimes when you roll the window down, it will hit the bottom plate or the slug on the speaker. Happened to me and i had to make a 1/8in spacer so i have 1/16th of clearance so i could roll my window down. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
